- Joined
- 15 May 2023
- Messages
- 48
- Reaction score
- 0
- Country
I'm looking to increase the ridge height of my semi detached house, but not sure the best way to go about it. The reason behind it is to obviously increase the ceiling height, as I want to then put a dormer on, but would much rather some decent head height than what i will end up with (around 2m). Not sure how to go about planning here:
1. Would it be best to apply for planning for just the ridge height extension, then do the dormer application?
2. Providing I do the above, would PD rights still be in play?
3. What would increase my chances of getting this application approved?
4. I also own the adjoining house (albeit not in my name). Is it possible to do an application for both at the same time, and would this be more likely to get approval?
I've attached elevations for existing and proposed here. I'll be looking to add around 450mm to the height. The house is on a slight hill, with the 2 neighbours to the left being around 400mm lower, and the neighbours on the right around 500mm lower. There is also around 5m of space between the houses on each side. I don't think the plans look bad, but if there's also a better way to do it i'm all ears. Any info would be great!
