Hi. Can you tell me what size drill bit you use to drill out the screws as I have one where the screws have rusted and I cannot get them to budge. So need to drill them out. Also, can you recommend some nice long length screw drivers as I am in need of a new set. Thanks
Oh, and if you wouldn't mind, it would be good to know the bits you use in the impact driver as well as the impact driver is a great tool for getting tough screws out a
Thanks for the reply and advice. Got to be a long reach pilot bit though. Do you know what thickness you use as I have drilled out the threads before trying to drill the screw heads off!
Hi. Sorry to keep pestering. Could you advise which drill bits and length you use as struggling to find decent length drill bits that mention cutting into steel. Thank-you
