So I’m into the new house, the one I’ve got the new RCBO board for and what fun I’m having discovering the current writing state.
Thought the kitchen would be good, after all how hard can it be……
Soo
I’ve got accessories on the downstairs ring final.
I’ve got accessories on the upstairs ring final.
Oven was plugged in, it’s a circa 1990 2.3kw job so wasn’t unsafe, just garbage.
Couldn’t find the 4/6mm cooker feed to start with, wasn’t sure it was fused, it’s fused, popped fuse (old Hager cartridge style board) expecting something with a high draw to be connected to it. Checked the electric shower just in case….. not that.
Oh hold on the fridge light has gone out… yep the 4/6mm feed from the board is powering the fridge and the ignition for the hob. I’d call that marginally over rated.
Wish me luck………
Floor partially up in 2 bedrooms already, looks like the bathroom needs a couple of boards lifting as well. Yay.
I’ll be ripping the kitchen out fitting/making good on a discrete kitchen ring and rerouting the 4/6mm for the double oven that’s being fitted @ around 4kw.
There is a question here.
I’ve got a 25mm gap between the block work and the plasterboard.
For the oven can I use a pattress box with a cooker outlet? Pattress will be fixed to the block work but is there any problem with it sitting proud? I’m not going to go with an integrated socket outlet so it’ll just be the oven.
Cheers
Lee
Soo
Wish me luck………
Cheers
Lee
