the main point is they worked in just one room, it was not a central system, so worked out cheaper, the things which are being pushed to heat our homes are large fixed units which replace the central heating boiler, but to cool they need a way to remove the condensate, so many are heat only which seems a bit daft, and also to heat and cool it needs a fan of some type.What ive read and watched about them, is they cant supply enough heat in the winter & you need a top up heat supply. Im talking air source not ground source.Yes.
They've been the "future" in many other countries for decades. The UK is finally catching up
Is it looking likely that these are the future of heating?
They work perfectly well when correctly specified & installed. A kw of heat is a kw of heat no matter how it's generated. 10kW from a heat pump is exactly the same as 10kW from a gas boiler. Places like Scandinavia, Canada, and the USA get much colder than here and have been using heat pumps for 30-40 years.What ive read and watched about them, is they cant supply enough heat in the winter & you need a top up heat supply. Im talking air source not ground source.
Air source ones?They work perfectly well when correctly specified & installed. A kw of heat is a kw of heat no matter how it's generated. 10kW from a heat pump is exactly the same as 10kW from a gas boiler. Places like Scandinavia, Canada, and the USA get much colder than here and have been using heat pumps for 30-40 years.
I have a possible job, that involves installing heat pumps in a group of 3/4. Installed in a day.
I haven't done any heat pumps, they said they would train meIf you haven't had training, get some.
Can a air source heat pump reliably produce the 10kw of heat constantly?
