Best solution for adding a shelf with lip to this keyboard stand
5 Apr 2011
Devon
I've got a third layer on my keyboard stand, but rather than adding another keyboard to it I want to add a shelf which spans the arms on which I can place several smaller pieces of equipment. Weight of the equipment will be around 5-6kg, but obviously most of that will be supported by the keyboard stand anyway.
The shelf will need to have a lip on the front edge to stop the equipment sliding off.
It needs to be at least 58cm wide and 32cm deep.
Something like an edge-top chopping board turned upside down would be perfect, but understandably I can't find one wide enough.
I've searched online for a shelf with lip but can't find anything suitable, certainly not deep enough anyway.
What would you recommend in terms of a solution. Should I resort to a cut of fibreboard or similar and then fit a length of angle edge or stair nosing trim to that to provide the lip?
Thanks in advance.
A piece of Contiboard, with an alloy carpet door strip screwed to the front edge, perhaps?
So many solutions - contiboard, pine shelf board, couple of wooden boards jointed together, bit of ply, chip, old worktop...... As to the lip, again, so many solutions!
Block board as will stay flat. Edge it with half round beading.
Fill. Maybe coloured spray can paint.
Might have to buy 8x4 then get supplier to cut up. Just a case of making it then. Keep the rest of board for another project..
If making yourself you may need track saw
Thanks for the replies.
So, I found a piece of chipboard for free, bought myself a mini circular saw from Screwfix to trim it down, CT1'd some aluminium corner trim from a cladding company to the front and sides, and screwed a length of timber to the rear/upper edge for strength and for additional clamping for the side pieces. Not very pretty but it works.
