Heavy duty mesh covered door seal
29 Jan 2011
Yorkshire
A wheelchair bound friend of mine has a front door frame that tends to get hit with the wheelchair from time to time. Sticky backed foam draught seal won't last long and the current strip of it is dropping off - but I notice on the top and the hinge side of the door, what I assume is the original V shaped seal for the door. That stuff is covered by a very fine mesh - giving it a shiny metallic appearance and seems to be as tough as old boots. Is it possible to get that sort of heavy duty seal still? - all I can seem to find is the standard foam stuff. Thanks!
Is it a plastic door?
There is (was) a very good springy metal strip, for wooden doors, in phosphor-bronze.
Door jam protection it's called.
Or I seen at trade show
Ram Board Door Jamb Edge Protection - 91.44cm (36") (36") https://amzn.eu/d/e4hof2s
You need to post a picture of what you mean
Sorry, didn't take one at the time. I figured it would be easy to find (really should know better :giggle: ). Will get a photo on next visit if needs be.
Construction is a bit unusual for a domestic door - it seems to be steel sheet on a timber frame.
No - not that.
Since found something that looks very much like it - but the old seal on the door doesn't look quite as thick/bulky as this, and it isn't clear to what degree this seal will compress. I'll need to dig further.
I used to have an old family house where the bronze strip was fitted in the 1950s, and still fine after 70 years. I found a roll of it in the shed.
It is better left unpainted which prevents sticking.
Turns up occasionally
These are the seals in question. When the door is open, they are pretty substantial and actually uncompress to around 20mm from the timber frame. At the side of the door where the original seal is missing, when the door is closed, there is a 10mm gap where the original seal would have compressed and sealed - and that of course is way too big a gap for any modern foam seals to handle. The door is actually faced with steel. So I'm thinking on balance, it probably is the sort of seal I've already found but any other thoughts/confirmations appreciated. Thanks!
That seal in the frame looks like a Schlegal aquamac 21, its a plastic coated foam seal, its a early form of composite door in that its steel faced both sides around a timber core, quite common on 80/90s new build and social housing, IG doors made loads of these, might even have IG stamped on the hinges
@crank39 Just googled it and I think you're spot on. It had something printed on the sealing face but it was so faint, I couldn't make sense of it - and I see QLON in some of the photos I've now found. The social housing makes sense in this case too. What threw me was the bits of foam that aren't missing had worn on the sealing face giving it a shiny almost metallic appearance.
That's me sorted now I think - thanks.
