- Joined
- 22 Jul 2016
- Messages
- 6,442
- Reaction score
- 1,244
- Country
So in a new build space, we may wish to effectively build a false wall 1M away from the block wall.
This will be for storage and the frame work is 2x2 or 2x4.
Height around 3m
We will be cladding most of the walls with ply or MDF.
However I need storage so would like close to invisible doors forming a wall.
I was thinking 10 feet sheets of 18mm ply maybe cut to 1M width hung on kitchen style hinges and either meter cupboard style latches or the push to open style catches. I can use steel strip to hold the bottoms of the door openings in place. Underfloor heating makes fixing to the floor awkward but I can cope with a ply base if needed.
How heavy is an 18mm sheet of 1x 3 m ply? Would traditional hinges be better? I need the outside to look pretty featureless.
TIA
Height around 3m
TIA
