I have used Araldite two-part glues for many years, but I'd value advice about the use of the two new 'mixing tubes', which came with today's product.
Having dispensed the required amount of glue (which I assume is automatically mixed by the tube), should I then dispose of the mixing tube? If both parts of the glue have been mixed in the tube, won't they have begun to harden and the tube then be blocked, and need disposing of? I suppose that if such is the case, after both mixing tubes have been used once, further use of the glue would be done by mixing the two parts as we did before, having poured some from the syringes on to a surface. Have I misunderstood anything? Thanks for any clarification.
I did post this question on Araldite's customer advice web page, but no response as yet.
