D
Deleted member 267285
Thanks mate, I understand the switch part at a and b, could the existing not be used for T1 and T2 and alter at the wiring center though? Sort of how I thought in post #8?A&B is simply a switch mate (battery powered) they go to 2&3 on the heatlink, all the switch part does is send power to the Brown wire on the corrosponding Zone valve, the existing wiring will do the rest, but as said already the Heatlink needs an L&N supply to power it and if the OP wants to use T1 and T2 to power the thermostat , he /she will have to run a cable for that and supply and Earth to the Heat link
