Burying fiber in flexible conduit from house to garage
23 Jun 2022
Germany
Hello, I am burying a fiber optic cable so I have internet in my garage. I have purchased the following flexible conduit to run the fiber optic cable inside:
Diameter of the Kabuflex 40 mm.
*Inner diameter: 32 mm.
I have dug a 20m trench 60cm deep. What I need advice on is the transition from inside to outside. I don't want to drill a hole in the external wall large enough to feed to conduit through. I assume I need a junction box and adapter on the outside of the wall that the conduit connects with?
Hope your fibre is ready terminated (or you have the kit and skills to do it).
Be very wary of minimum bend radius on the fibre.
Ideal way would be to run the duct under or through the house wall (at trench level) then either gentle curve to vertical or gentle uphill to subfloor.
If you can't achieve that then yes, gentle curve up to vertical, nice IP65 adaptable box big enough to house your fibre-copper interface and then throw cat 5e or cat6 through the wall.
Drilling a 16 or 20mm hole through a brick or brick/block cavity wall is a 5 minute job with an SDS and a long bit, again you'd have to watch minimum bend on the fibre going through the wall but totally doable and a much easier/better job than trying to fish wire through a 6 or 8mm hole.
If it's at some kind of ruggedised 2 core patchlead rather than chunky armoured 24 core the bend radius available to you in an IP box isn't so small you couldn't spiral round and take it straight through the wall, what sort of cable were you looking to put in?
Do I understand that you are having a "separate' to your house fibre feed to your garage? Seems an expensive way to go. Why don't you run a length of Cat5 or from your in-house router?
Do you really need a fibreoptic cable to achieve that - it's something I've never heard of anyone doing within domestic premises.
Your life would be very much simpler (and your wallet happier!) if you used conventional copper Ethernet cable, and even simpler if (distance permitting) you used WiFi.
Only two realistic reasons to do it are bandwidth (10G or higher) and/or distance.
Fibre isn't ruinously expensive though, about £60 for a pair of optical transceivers and about £50-60 for a outdoor rated armoured patchlead.
Indeed, but ...
... maybe not "ruinously expensive' but, as I said, I personally have not heard of anyone doing it within a domestic property. Do I not 'get out enough' ? :-)
There is the other big advantage of immunity from any issues with differing earth potential at either end of the link. Not an issue i've ever experienced with network cable tbh but have had problems with audio links in the past.
One might hope that the network cable would be isolated from earth.
No, I'll run fiber from the switch in my house to the switch in my garage. Both switches have SFP ports and I have SFP modules. The fiber cable is pre terminated 100m LC-LC.
The reason I didn't want to use ethernet is because I read there are risks to the equipment if lightning strikes nearby. Some in networking forums strongly recommended using fiber when going from building to building.
I suppose that's a theoretical risk, but presumably no greater than the corresponding risk in relation to (copper) landline cables (particularly overhead ones) and TV aerial cables etc.?
Yes. I have strung longish lengths of cat5 outdoors/between buildings and crossed my fingers if the thunderclouds started appearing. That's not a ridiculous price for a high bandwidth noise-immune link, as earlier do be careful with the bend radius on the fibre.
The value of connected gear and consequential losses (data especially) might make that risk worth mitigating.
I will have a access point connected to my switch via ethernet quite close to the garage. Could I also use such an access point as a WiFi extender and install another access point in the garage to provide good WiFi coverage to the garage?
