I've made a new first-floor bathroom with a toilet on a wall over the side passage. The main combined rainwater/sewage drain runs under the middle of the side passage. So I thought it would be easy to make a new soil stack into the existing drain. But now I think it's quite hard, access is too tight for an inspection chamber or even a rest bend.
I've dug down to find the old clay pipe (about 135mm diameter), and checked this is the pipe that goes into my main drain (inspection chamber about 6m away):
But that hole is about as wide as it can get without undermining foundations or going over boundary. The top of the pipe is about 450mm below the surface at this point.
There is not space for an inspection chamber join, and no space for an underground rest bend, so my idea is to make a 92.5 bend in the black plastic above ground then run it in from a short height at 45 degrees. This is my design so far (with an additional join in from a new ground floor toilet):
What do you think? Could this work? The hole looks just big enough to get a small angle grinder down to cut the old clay pipe, but then all my foul and rain water drainage is out of action til I can repair it.
I'm really stuck with this one and no local drainage firms seem keen, haven't even got a quote yet. I would rather not take this on myself but have a baby due next month so really need to get this bathroom working, so any advice would be great.
