Post some pictures furher back so that we can see a bigger picture.
Andy
Oh that's great if you don't need to concrete under it. And I've seen people just put an old slab under rest bend.Would a 300mm chamber fit?
I would make the hole longer so it it easier for you to work/stand in, also dig down and around the pipe at least 200mm underneath it for more wiggle room. Then use pea single under the chamber and then fill around it once fitted.
Andy
No, what I'm suggesting is, come down vertically with the new Stack, fit a junction into the existing pipe, then use a slow radius bend on the bottom of the stack to angle it across to line up with the main run. You haven't got enough room for a chamber, and I think it'll cause more issues that it solves, provided the existing run is accessible, and you fit an Access Point on the new stack, then I don't think you need to do much more.I can't quite picture this, you mean run another whole 110mm underground pipe the 6-7m to the main drain? That would be a lot of digging!
