But a fan isolator useful.Why is it "totally different"? - a fan FCU or isolator is just as 'unnecessary' as is the OP's SWA.
Anyway I'm not gonna win you rewire houses in armoured and ill use twin and earth.
I like itI had an issue about 10 years ago, I installed trunking and local isolators in a plant room for a row of 8 pumps. I don't recall the power ratings but I used all the same size isolator and wires, it was highlighted some were oversized for the smaller pumps and required changing. The consultant would not sign off until I 'corrected' them despite trying to convince the smaller pumps were likely to be upgraded (As informed by Grundfoss). I had the last laugh though, I wrapped the isolators and carefully hid the larger wiring in the trunking, a year later I charged a fortune to upgrade when the bigger pumps were installed and the consultant had to pick up the tab.
When they are being used as an earth they would need to be inspected.I don't believe it's a probably having the glands plastered over - IF they are correctly installed in the first place.
I'm not sure why you may think they HAVE to be accessible. When you consider that earthed metal conduit is full of threaded joints, that gets plastered over sometimes in purpose built flats etc - I don't see any difference.
I don't envisage any danger in what the op is proposing - but to me it's a rough job.
One could certainly 'get away with it', and I don't suppose the next man would bother himself by re-doing it.
It would be a bit naughty having non-sheathed cable for 2 inches just before the box - bearing in mind the cores would only be protected by the bedding - the bedding is technically not the same as sheath, and this can be either tough as old boots, or very crumbly.
I'm getting increasingly confused, particularly about some of the comments.If I was him I'd get a spark in to gland the 5 sockets was it, wont take long no bodge that way.
Oh well yes if thats the case, connect the sockets screw them back do the relevant tests and dont worry about it.I'm getting increasingly confused, particularly about some of the comments.
If my understanding is correct (maybe not?), but as the OP has recently reminded us, it seems that the armour has been 'cut back' and is now buried under concrete. If that is remotely true then:
(a) there's no point in people going on about 'glanding the SWA properly', since it appears that armour is no longer available to anyone ... and
(b) all of this discussion/argument is therefore about whether or not there is a (theoretical, but unachievable) need to earth some metal armour which happens to be surrounding a cable which is entirely embedded in concrete and which therefore will never be accessible or touchable.
In other word, in the situation the OP finds himself in, I would day that the armour is a total irrelevance.
I am perhaps gradually coming to understand a bit of your thinking - so do I take it that you feel that 'being useful' means that something is not 'wrong', even if it is 'unnecessary' ... and what about the 3A FCU for a fan - I would personally certainly not regard that as useful - so is it perhaps 'wrong'?But a fan isolator useful.
As I've said repeatedly, this discussion is nothing to do with what you or I would do. I personally would not waste time and money doing something that I regarded as unnecessary.Anyway I'm not gonna win you rewire houses in armoured and ill use twin and earth.
