Yes, nice idea.you could use one of these instead of a coax outlet.kenable Ready Made Faceplate Module F Type Screw Satellite Panel Mo...
The AV-MOD1FCONN module is a 50mm x 25mm clip in module the F Connector is a coupler allowing you to connect a standard male cable to the other side e... [se...www.kenable.co.uk
(and it's even cheaper to make your own!!. Blank plate, f joiner and drill!)
Thanks Sureitsoff, good idea.you could use one of these instead of a coax outlet.kenable Ready Made Faceplate Module F Type Screw Satellite Panel Mo...
I always use a right angle plug on the outside ie room side so that the cable goes parallel to the wall as well, much neaterYes, nice idea.
It may confuse a few into thinking they have a satellite feed though
A right angled f plug on the inside, may also be needed (depending on the depth of the back box), to avoid too tight a radius on the cable.
Thanks, yes that will look neater.I always use a right angle plug on the outside ie room side so that the cable goes parallel to the wall as well, much neater
