Light and extractor fan won’t run together when operated by new kinetic switch?
My question: Once you have removed the pull switch and got the wifi switch working, how are you intending to operate the bathroom light?
I really don't know how you think that:
is the same as this
Restore the 2 wires arrowed green, disconnect the 2 wires arrowed red:
Then add the brown, black and grey that EFL showed.
This is it! This worked. As my username suggests I’m not the brightest when it comes to this. A million thank yous. EFLs explanation confused me a little.
I’ve electric taped off the wires that don’t connect anywhere anymore but it’s probably best to put a small connector block on each(?)
There is a kinetic switch that pairs with the receiver. Everything now works well including the extractor fan on the timer.
Have tried the yellow wire instead of the black with red sleeve.
Not instead as well. The fan to get run on needs two supplies, one is un-switched, the other is switched, so the un-switched powers the fan, and the switched triggers the fan. Without this one can't get the 15 minutes run on required with a non opening window or no window.
