- Joined
- 27 Sep 2022
- Messages
- 298
- Reaction score
- 23
- Country
I couldn't agree more but I thought I clarify this upfront based on my previous posts where I few members pointed that this is a UK forum so UK regulations apply in the forum.It's not about UK laws. it's about the laws of physics.
That's OK, but don't forget up and under for the cold feed. Also the vent and feed should be maximum 150mm apart, as you've possibly seen if you've been reading up on it.I thought, I'll start a new thread for clarification. Does this look right? If I have understood it clearly, it is a flow loop from boiler to rads?
Thanks. I have got a pre plumbed pump and motorized valve that came with the boiler. I have marked the picture with arrows for clarity. What this small screw with a vent for (bottom left on pic) ?That's OK, but don't forget up and under for the cold feed. Also the vent and feed should be maximum 150mm apart, as you've possibly seen if you've been reading up on it.
Looks like a vent but it won't do much venting in that position, but it probably isn't essential. Is it possible to rotate the pipe so it's upwards, or would the vent screw then hit the wall?What this small screw with a vent for (bottom left on pic) ?
Yes, assuming it's pumping from right to left, which it should be if it's a pre-plumbed arrangementSecondly, Do I have the connections right from boiler and into the flow pipe?
you mean the whole thing so pump is facing upward direction?Is it possible to rotate the pipe so it's upwards, or would the vent screw then hit the wall?
No, I meant just the bits after the 3-port valve. Looking at the top of the T, towards the 3-port, rotate it 180°It hasn't been fixed yet, I was just holding it this way to ascertain correct orientation.
The motorised valve, filter, pump came with the boiler (Viessmann 100-w heat only wb1b). I intend to install it for central heating system only as I have direct source for water heating. If this is installed correctly I intend to get an indirect cylinder (with coil and immersion element) and install it as you say via Y or S plan system in future. If I leave the motorized valve as it is and leave it at central heating it should work fine for central heating?That's a 3 port valve, so you would be setting the system up as a Y plan with Ch and a Hot water cylinder. It will need a motorised head that would be controlled through what called an interlock, so a couple of thermostats and a programmer. Not the best TBH so be prepared to swap out the 3 port motorised valves during it's life. It would be better as an S plan with 2x2 port valves. Feed and vent would be piped in before the pump even then though, is setting it up as a sealed system not possible?
As the 3 port valve sits then it's AB = the inlet from the pump. A = the outlet to the Rads, B = the outlet to the Hot Water cylinder, forget about the air vent that's on it, it's kinda pointless where it is, either cut it off and cap or just leave it locked off and never touch it.
Yes. Obviously you need to blank off the pipe going to the future HW cylinder.If I leave the motorized valve as it is and leave it at central heating it should work fine for central heating?
Personally I prefer open vented, but if starting from scratch there probably isn't much in it costwise.I am skeptical going for a sealed system (based on my limited knowledge) but I keep reading the debate about sealed vs OV system due to maintenance involved. Are there any benefits in running it as a sealed system, I need to install an expansion vessel for conversion, Correct?
