D
Deleted member 294929
I think it's better to hang the clothes using hangers than folding on a drying rack, and if you have something like this much better.
Looks very good. I used to have one of these in the bathroom of my flat
F in hope not my Heat pump is in a shed and that's where its staying.
If ever we have an extremely cold winter, I guess you could use some kind of heater to protect it.
The roof and the walls are all insulated
Fine provided you don’t see any signs of mould which would indicate lack of ventilation .Is it okay to dry clothes in a small confined space with window open or will it still cause damp/condensation?
Would it not have a frost stat?My boiler is in what was the coal house (a cupboard under the stairs, accessed by a door on the driveway). No insulation, solid bricks walls and a wooden door with a gap underneath it.
Coldest recorded temp we had was something like -7 and all was fine. It generates heat when on and when not meeting demand for hot water/heating, periodically switches on as part of its front protection.
No it has an "integral frost protection" system which kicks in below 5 degrees according to page 9 of the manual. This is separate to a frost thermostat.
That's pretty much what I meant. Newer boiler may have one built in . Lots of older boilers wont
OOI, what fan have you got and how big is your bathroom?If you have a gap under your bathroom door, this is absolutely fine.
We dry our walking boots and jackets in the bathroom. Rather than have the fan running, we open the window and shut the door. I can feel the suction of air under the door as the moisture is pulled from the room. Don't get a spec of mould in there, and the room is 50% external solid brick.
extracts a fairly high volume of water per minute
Surely you mean air?...........
