- Joined
- 15 Apr 2018
- Messages
- 303
- Reaction score
- 4
- Country
Mr Rusty
Thanks for your reply.
I have cut the timber for the frame based on a 25mm over hang of the base so that the centre of the 4x2 sits on the frame, so add on the battens and cladding and the overhang is about 60mm , Do you see a problem with this?
I was hoping to avoid sheathing the frame and have actually "designed" it to be 2 structures that will be bolted together I was going to use builders straps and lots of noggins. If that doesnt work then it will have to be sheathed.
What would you advise to seal the raw edges.
Thanks for the links I will investigate.
I also did a quick search for the membranes as I only really need 15m x 2.2 and saw these: though I am a bit dubious
www.toolstation.com
Any thoughts?
I also see there are few sellers on ebay selling tyvek by the metre which could work out reasonable
Rhinovent Ultra Breathable Membrane Classic 1 x 50m | Toolstation
• BBA certified medium weight breathable roof tile underlay • Suitable for warm and cold roof applications • Requires no ventilation if installed in accordance with instructions
www.toolstation.com
Any thoughts?
