Thanks I'll try that tonight. If it is 0hms there any idea where to look next?
The brushes are the carbon blocks than connect power to the rotor. They press against the commutator, which is the segmented copper ring at the left hand end of the rotor (the bit that spins!) They are pressed against the commutator by the springs that push them into the brush holderWhere are the brushes on the drill please?
It could be the fault of course but I take to be a good sign.So between the two white wires I got 0ohms well 00.6 is that close enough. I can't get a reading in the live and neutral incoming I think I'd need to pull the wires out.
I don't think I have done that yetAs this is an 110v drill, has the OP confirmed there is output from the 110 transformer yet, with a meter? He should see 110v between the two poles, 55v between each of the poles and the earth connection at the 110v socket.
