I am suffering from fuel drain back to the tank on an older car which uses a mechanical fuel pump, it's the glass bowl type one as seen in the attached image. Fuel is also leaking into the oil through the diaphragm, so the whole thing needs refurbing.
The car is used weekly and each Friday the fuel has drained back to the tank, which makes it a pain starting as there's no manual lift pump (primer). I don't mind cranking a bit to build up oil pressure, but sitting there 10-20 seconds is causing premature wear on the battery and starter each week.
I have decided to rebuild the pump which should be fairly straightforward, however I'm not sure how to get the check valves out of the pump housing. They are apparently 'peened' into place using a suitably-sized socket and then a punch to bend metal over the top of them to hold them in place.
How would I go about 'un-peening' them and then 're-peening' them into place? Anybody here still know how to maintain these? Annoyingly, the later pumps (with a the manual primer) used a plate held in with screws to secure these valves which would be much easier!
