    Dismiss Notice
Anglia 105E fuel pump
Discussion in 'Car Repairs / Maintenance' started by johnad, 22 Sep 2018.
  1. johnad
    johnad
    17 Mar 2005
    395
    Thanks Received:
    Country:
    Following on from my previous threads about issues with my 105e engine fitted in my boat
    After all my questions on hear it finally runs ok after fitting new points, condenser, plugs, coil, etc
    New alternator so now charging ok, also new fuel tank filter and fuel lines.
    The only issue I have left is that if it has been standing for a week or so it will not start
    Then runs for a while and cuts out due to fuel starvation (I think)
    I have no fuel in the carb so its drainning back into the tank
    I have to use easy start to get it running/pumping then it runs
    So I'm suspecting the old Manuel fuel pump
    So is it time to fit an electric pump ?
    If so what one size etc ?
    I'm also assuming I just power this from the ignition switch ?
    More help needed please.
  2. Sponsored Links
  3. Peter.N.
    Peter.N.
    26 Sep 2006
    1,712
    Thanks Received:
    258
    Dorset
    Country:
    • Thanks Thanks x 1
  4. Burnerman
    Burnerman
    7 Feb 2008
    20,272
    Thanks Received:
    3,949
    Northumberland
    Country:
    I think an electric pump would be a good move too....bear in mind that the required fuel pressure for these old carburettors was in the region of 3 psi so any pump geared towards fuel injection systems would be too high.
    Wire it through the ignition switch so it becomes live at the same time as the ignition coil.
    John :)
  5. johnad
    johnad
    17 Mar 2005
    395
    Thanks Received:
    Country:
    Great thank you
    Are they fairly reliable ?
    I will order one today
    Should I just leave the old one in place ?
  6. Burnerman
    Burnerman
    7 Feb 2008
    20,272
    Thanks Received:
    3,949
    Northumberland
    Country:
    Yes, they are reliable.....most vehicles have an electric pump in the tank, submerged in the fuel. The beauty of an electric pump is that you have fuel on demand, without cranking the engine.
    The old pump can be either left in place, or removed and a suitable steel blanking plate fitted to cover the hole in the block.
    John :)
  7. Nige F
    Nige F
    28 Jun 2005
    20,129
    Thanks Received:
    1,495
    Country:
    Yes, but with the old SU you could hear from the clicks if it was working or not;)
  8. Peter.N.
    Peter.N.
    26 Sep 2006
    1,712
    Thanks Received:
    258
    Dorset
    Country:
    I had an SU pump on a Morris Oxford I converted to diesel but it was a bit intermittent, you would feel the power dropping off so you had to drive over a manhole cover or something similar and that would start it up again.:)
    Peter
    • Thanks Thanks x 1
  9. Burnerman
    Burnerman
    7 Feb 2008
    20,272
    Thanks Received:
    3,949
    Northumberland
    Country:
    I seem to think the Mini SU pump was a short suck, long blow - on the rear subframe collecting all the road crap, and the Minor one was the opposite - stuck on the N/S front bulkhead?
    John :)
    • Like Like x 1
  10. Sponsored Links
  11. Mottie
    Mottie
    27 Feb 2017
    4,744
    Thanks Received:
    535
    Essexshire
    Country:
  12. johnad
    johnad
    17 Mar 2005
    395
    Thanks Received:
    Country:
    Finally I have fitted the new electric fuel pump wired from the ignition switch
    After charging the battery it started fine and ran for about 10 mins then just cut out ?
    After a couple of turns it then restarted another 10 mins same thing just died
    Could this be a fuel thing ?
    The engine has now had new fuel tank, filter, fuel lines and pump
    New plugs, points, coil, condesnser, and a new alternator
    I'm now at a loss so any help would be appreciated.
  13. Burnerman
    Burnerman
    7 Feb 2008
    20,272
    Thanks Received:
    3,949
    Northumberland
    Country:
    I think, next time it cuts out, is to check if the float chamber is dry - but 10 minutes running is much longer than a dry carb would allow - and could indicate a component failing due to heat.
    Do check any in tank fuel strainer or filter. How easy would it be to sort out a tank above the carb, just to give it temporary gravity feed?
    Is the new coil getting hot, John?
    John :)
    • Like Like x 1
  14. johnad
    johnad
    17 Mar 2005
    395
    Thanks Received:
    Country:
    All the fuel components are new tank fuel lines filter etc
    But it would be easy to setup a temporary tank just to be sure
    I will also check the new coil to see if it's getting hot
  15. Nige F
    Nige F
    28 Jun 2005
    20,129
    Thanks Received:
    1,495
    Country:
    Has the tank got a vent to let air in ? The old "polish in the pinhole of the motorbike tank cap " as we used to say to the obsessive polishers.;)
    • Thanks Thanks x 1
  16. Burnerman
    Burnerman
    7 Feb 2008
    20,272
    Thanks Received:
    3,949
    Northumberland
    Country:
    Not so daft, that one (y) Been caught out before!
    John :)
  17. Burnerman
    Burnerman
    7 Feb 2008
    20,272
    Thanks Received:
    3,949
    Northumberland
    Country:
    Just scratching what remains of the brain cell.....just wondering if the pump has enough pressure to lift the needle valve off its seat - but if the thing can run for 10 mins then it can't be that bad!
    Also wondering if the coil is meant to have a ballast resistor - where its a 6v coil, gets 12v to start up, then reverts back to 6v for normal running....maybe we've discussed this one before.
    I'd also use quality points - I used to use Intermotor in the past and failures were frequent - as were the condensers.
    The petrol pipe doesn't run close to anything very hot, perhaps?
    John :)
Loading...
Share This Page
