- Joined
- 30 Oct 2021
- Messages
- 44
- Reaction score
- 3
- Country
Long story short, we have:
1950s house
Double glazing, only about 10 years old, good condition. No condensation between the panes.
Trickle vents OR openers that we leave open a crack during the night
Two adults in the house, no pets
High outdoor humidity (it was 91% RH last night!) and humidity monitors inside, they were sitting at about 67% last night. As mentioned, very humid outdoors where we live so difficult to control this
No MVHR
Type 22 rads in every room, gas boiler, smart thermostat controlled, doesn't let the temperature drop excessively overnight. Boiler flow temp currently at 45C, only needs to run occasionally as the house is well insulated: 400mm loft insulation (rockwool), 60mm anthracite bead cavity wall insulation, 100mm rigid board insulation beneath screeded floor on ground floor. PLUS a recently installed highly insulated composite front door.
This morning, when outdoor tempeatures dipped to 3C, there was quite a bit of condensation on the room-side of the inner panes of our windows, along the bottom of the unit, mostly. Not in every room, but in most - and there was enough moisture to require wiping away to prevent mould.
My question = is there a way of drastically reducing condensation in terms of adjustments to the current fabric of the building, or is it really just unavoidable in our case. No, I'm not going to stop breathing!
I am aware I could try a dehumidifier but I'm a little reluctant to rely on that. I'd rather deal with the source of moisture / problematic cold spots if possible.
Any thoughts gratefully received...
1950s house
No MVHR
