D
Deleted member 294929
Black glass rainbow speckledWhat splashbacks you doing?
Black glass rainbow speckled![]()
Glass?, you must be loaded. Hope they get the socket cut-outs in the right place.![]()
Is grind size adjustable?I'm a fool who's really not loaded.
I'm struggling with this machine. Early stages I thought ok this is easy. Started to tweak and found it was getting worse and not better.
one of the most key elements is extraction.A good tasting espresso is getting the sweet spot between under extraction and over extraction.
the best way to check is to weigh the ground coffee and the weight of the liquid extracted + the time that takes.
A starting point is a brew ratio of 2:1, ie 18g coffee produces 36 grams of espresso. Aim for 25 to 30 seconds to pull a shot
the biggest factor that affects shot time and extract ratio is grind size
Ive no idea what elements you can adjust on your bean to,cup,machine
As I suspected. Plenty of faffing required. You'd want that when you‘re on the way out at 4 in the morning….
That's not trueYou're not being helpful Pod man.
I find Nescafe tooo bitter.Brother's got a 5k coffee machine. I always ask him where the proper coffee is - Nescafé.
I pay someone to grind my beans to just the right texture and then have them pack just the right amount into a little aluminium capsule which I just pop into my machine which then forces hot water at just the right temperature through it to produce the perfect cup of Joe.Takes me just 2.5 seconds to get the contents into my coffee machine. No need for a week off work to get that right. No mess, no waste.I've got the week off (hopefully) gives me time. Once the adjustments are correctly set then I'll be flying.
