I have six light sensitive LED lamps outside our house, on the wall and along the path which are all flashing in unison! To complicate matters, all are controlled from a timer switch (indoors).
Normally, they come on when it is dark and go out when daylight, as you might expect. However, when I turned off the timer switch I noticed that all six lamps are flashing regularly, but very briefly, all at the same time and at exactly once a second.
I would expect that with the power turned off there would be no lights, and these flashes are as bright as the lamps when they are lit properly.
I suspect that as all six are doing this at exactly the same time it may be down to the timer switch. If I turn off the appropriate circuit breaker they all stop as you would expect.
I'd welcome any comments and suggestions. Thank you.
