An FCU is really an accessory, rather than an OCPD imho
So therefore, an FCU does not create a circuit.
Disagree. I dont agree with it.So therefore, an FCU does not create a circuit.
We have discussed this ad infinitum. As the definition in the regs is written, an FCU does create a circuit, but that makes no sense. If that were the case, then adding an FCU (and things supplied by it) to an existing circuit would be notifiable, but even before the extensive relaxations (in England) in 2013, adding an FCU (and things supplied from it) to an existing circuit was one of the very few things that was explicitly not notifiable. It would make no sense for it to be their intention that the extensive 2013 relaxation of notification rules would have the reverse (of 'relaxation') effect in the case of FCUs!So therefore, an FCU does not create a circuit.
Totally right.We have discussed this ad infinitum. As the definition in the regs is written, an FCU does create a circuit, but that makes no sense. If that were the case, then adding an FCU (and things supplied by it) to an existing circuit would be notifiable, but even before the extensive relaxations (in England) in 2013, add an FCU (and things supplied from it) to an existing circuit was one of the very few things that was explicitly not notifiable. It would make no sense for it to be their intention that the extensive 2013 relaxation of notification rules would have the reverse (of 'relaxation') effect in the case of FCUs!
If a fuse were in a DB or CU you would presumably have no problem in regarding it as an OPD, so why different if it's in an FCU (or anywhere else, come to that)?An FCU is really an accessory, rather than an OCPD imho
You're making the mistake of applying comment sense. If one takes literally BS7671's definition of 'a circuit', then adding an FCU does create a ('new') circuit, and hence would be notifiable (in England, but not Wales).The way I view it is that because the FCU is not notifiable, it's not a circuit.
... but plugs are not part of the fixed installation, hence outwith the scope of BS7671.It is only a method of connecting an appliance. The fuse just replaces the one you would find in a plug.
If and one installs a triple socket (with it's fuse/OPD) one has not supplied anything through that OPD = tht only happens if/when someone plugs something in (then yet another fuseThere's no confusion around a triple socket.
Indeed - and from the same document ...Fused connection unit .... A device associated with the fixed wiring of an installation by which appliances may be connected and having provision for a replaceable cartridge fuse link .... Source 18th edition AMD 2 - definitions
In what way are you suggesting that the "replaceable cartridge fuse link" in an FCU does not satisfy that definition of an OCPD?Overcurrent protective device (OCPD). Device provided to interrupt an electric circuit in case the conductor
current in the electric circuit exceeds a predetermined value for a specified duration.
If that is the entire definition, that could be taken to be that a Fused Connection Unit is expressly used to connect an appliance to the fixed wiring and therefore not for installation within fixed wiring. In other words not suitable as the source for a fixed spur.Fused connection unit
