No, pings back up.I don't know if it still applies these days, but originally the wire elements used to be 110v each, connected in series so any failure shut down everything.
Does the thing latch on when the handle is depressed?
John![]()
Lol.its not plugged in
Disassemble it and check the continuity of the heating element with a multimeter. You may even see a break in the wire without testing. Theoretically, replacement wires would be available from china. But people will warn you china parts might cause your toaster to catch fire.
It's also not deep enough to accommodate high pieces of toast and I have to turn them over, but that's a separate issue
You put your bread on it’s side then it fits .No, pings back up.
