- Joined
- 22 May 2016
- Messages
- 12
- Reaction score
- 0
- Country
Hi all
In the corner of my garden I'm planning to build a ground level deck (it will be raised slightly off the ground but the top of the deck will be 30cm or less from the ground).
I want to have some festoon lights around the area and was thinking how best to hang them around the decking area.
My current thinking is to use the posts that will form the deck supports, and extend these upwards, 2.5m above ground level, and hang the lights over these. I'll only make 3 posts this tall.
So it's not a pergola or gazebo, it's just a deck with 3 corners having the support posts raise up.
Firstly, are there any planning permission issues here? It's not a building. The deck level is no more than 30cm above ground. Could a neighbour object?
Secondly, if the posts are going to be 2.5m above ground, bearing in mind they're also supporting the deck, how deep below ground should they go and what thickness should they be?
Was thinking I'd need to go 70cm below ground and use 10x10cm posts if I can find them long enough!
Any thoughts on this? Any better ways to suspend the lights? Are there any poles that could attach to the deck posts instead? We have lots of strong wind here so need a robust solution.
Thanks for your thoughts.
