Yes, there should always be a fall on the pipe, for that condensate then 19mm per m as a min. Whoever is fitting it should know all of that and I am getting the feeling that you are trying to fish out all the info needed to DIY it
Yes, there should always be a fall on the pipe, for that condensate then 19mm per m as a min. Whoever is fitting it should know all of that and I am getting the feeling that you are trying to fish out all the info needed to DIY it![]()
Why does he think that?Is he reading this thread?The engineer is not happy with me now. He phoned back ****ed off as he assumed I reported him to GasSafe
All pipes should be "Free draining" which just means the bubble on the level is showing slope towards the direction of flow.Is there any need for the condensate pipe to be adjusted so it drops at an angle? I read that it shouldn't be horizontal (like it currently is)
Eh? If the run is right to left as in this case and the bubble was to the left on the level (to me that would be towards the direction of flow, as the flow direction would be to the left, unless I have picked this up wrong) then the water would be trying to run uphill??? Regardless of what any thing Gas Safe have to say about it.All pipes should be "Free draining" which just means the bubble on the level is going towards the direction of flow.
That's it regardless of stupid "Gas safe" ******.
I would think it's fairly obvious which way the pipe should be sloping tbh.Eh? If the run is right to left as in this case and the bubble was to the left on the level (to me that would be towards the direction of flow, as the flow direction would be to the left, unless I have picked this up wrong) then the water would be trying to run uphill??? Regardless of what any thing Gas Safe have to say about it.
In this case for the fall to be correct then the bubble should be to the right on the level, which in my book would be the opposite to the direction of flow, unless, as I say, I have picked it up wrong.
Believe you me, it isn't to some. As this is primarily a DIY forum I've found over the years that there are some real rookies with next to no knowledge and what may be obvious to some isn't always to others. Over the time I've been here I've learned it's better to be quite specific, just in case.I would think it's fairly obvious which way the pipe should be sloping tbh.
Yea, probably right in fairness.Believe you me, it isn't to some. As this is primarily a DIY forum I've found over the years that there are some real rookies with next to no knowledge and what may be obvious to some isn't always to others. Over the time I've been here I've learned it's better to be quite specific, just in case.
Sounds like me haha, I've only just bought a place and trying to learn. I find these DIY forums incredibly usefulBelieve you me, it isn't to some. As this is primarily a DIY forum I've found over the years that there are some real rookies with next to no knowledge and what may be obvious to some isn't always to others. Over the time I've been here I've learned it's better to be quite specific, just in case.
At the end of the day, that's what it's all about. If we can help and point people in the right direction when it comes to doing their own work, if they want to try, then the forum can only add value.Sounds like me haha, I've only just bought a place and trying to learn. I find these DIY forums incredibly useful
Don't lecture anyone on this forum offering advice. Bad or not.At the end of the day, that's what it's all about. If we can help and point people in the right direction when it comes to doing their own work, if they want to try, then the forum can only add value.
It can be a minefield though with some DIY'ers trying to bite off more than they can chew and the inevitable keyboard warriors who supply really erroneous advice, who's best friend is google and can end up doing more harm than good, luckily though they tend to be called out quite quickly.
This forum is testament to this every other post is a problem caused by cowboy, bandit workmanship by so called registered or legit professionals.
Yes, DIYs can and do **** up but its with the best intentions at heart.
I'll doff my hat to @Madrab and thos on this board who are conscientious and skilled and offer their time foc. It's a great thing...Which is at least part of the reason I insist on doing the work myself, wherever I am able, and why so many others choose to attempt to do the same.
But holy ****, the industry is dreadful.
All trades suffer the same.
Good uns and bad uns.
