I had a new circuit put in by an electrician as part of a CU relocation job. The circuit is on a 32A RCBO and has a 6mm2 TE cable wired into it. The work was done a year ago and at the time it was feeding my oven and everything worked well. As part of some renovation work, we've taken out our oven and will be wiring in the induction hob onto this circuit. It's been turned off at the CU for about 4 weeks. I have since tried to connect the Induction hob and the RCBO popped immediately, so I took the hob off, inspected the conductors, and wired it only into a 45A DP switch with no load attached it and again it popped immediately and I could see a small puff of smoke come out of the RCBO. I'm confident the conductors or the cable haven't been damaged in any way. I've contacted the electrician to see if he can come down and test but in the meantime I'd appreciate any thoughts on what could be going on here?
