Perhaps I should of been clearer. I should of said local.Not found Google yet then?
Hospa Screw, Chipboard, Countersunk Head with PZ Cross Slot, Fully Threaded, Stainless Steel - Häfele U.K. Shop
Screws Hospa Screw, Chipboard, Countersunk Head with PZ Cross Slot, Fully Threaded, Stainless Steel - order in the Häfele U.K. Shop.www.hafele.co.uk
I'll disagree with you on that point - Hospas are the go to in the kitchen trade simply because they can be driven straight into MFC withgout pre-piloting but with minimal damage, unlike cheap screws. They also come in BZP finish as standard. So no, any old screw isn't as good and many screws burr up or burst the melamine coating on carcasses.Any broad thread with hold well in chipboard.
So I am just about to fit 14 new cabinet doors and will be using the screwfix Hafele hinges they come with the fat screw attached for the carcus plate and normal screws for the door cup, do you think I should not use the supplied screws but instead invest in the hospa ones.I'll disagree with you on that point - Hospas are the go to in the kitchen trade simply because they can be driven straight into MFC withgout pre-piloting but with minimal damage, unlike cheap screws. They also come in BZP finish as standard. So no, any old screw isn't as good and many screws burr up or burst the melamine coating on carcasses.
The best alternative in terms of performance is probably the Reisser cutter (although they aren't quite as good IMHO), but with the caveat that getting those in BZP finish often isn't that easy, either. You can generally pick-up smaller quantities of Hospa screws from sellers on eBay, but as they are normally a kitchen trade supply, unless you have a kitchen component supplier locally who is willing to supply to non-trade, you will most likely be out of luck. In my experience Hospas aren't something a builders merchants or ironmongers stock, although I do have one trade ironmonger in Manchester who can get them to order next day (however, in trade box sizes)
Great I will have a look![]()
Hospa Screw Countersunk Head Fully Threaded Galvanized Steel
Hospa Screw, Chipboard, Countersunk Head, with PZ Cross Slot, Fully Threaded, Steelwww.solmer.co.uk
Solmer have an ebay account too but they don't sell the full range on ebay.
I'd just use the ones supplied unless they are Chinese...So I am just about to fit 14 new cabinet doors and will be using the screwfix Hafele hinges they come with the fat screw attached for the carcus plate and normal screws for the door cup, do you think I should not use the supplied screws but instead invest in the hospa ones.
Which is partly why kitchen fitters tend to use Hospas...I looked at the rizer cutter ones but as the cabinet frame is 18mm i just thought that a lot of useful thread is wasted/ cut away to make the cutting angle leaving not much actual thread in the frame.
I don't know but they are Hafele so hopefully good.I'd just use the ones supplied unless they are Chinese...
You saved me an extra post.When I was breaking down the very old kitchen cabinest I came across thoses - never seen them before and thought they looked really good and strong so i salvaged them for future use.What is your opinion of Confromat screws?
One-Piece Connector, with Ø 8 mm Head, for Ø 4 mm Drill Hole, Confirmat - Häfele U.K. Shop
Connectors Steel, with cross slot - order in the Häfele U.K. Shop.www.hafele.co.uk
Over the years I have known guys that use them with the drill bit that does the clearance hole, counter sink and pilot hole at the same time.
Oh, and good to see you back. Respect.
