- Joined
- 3 May 2021
- Messages
- 7
- Reaction score
- 0
- Country
Hi all and happy new year
It’s been a while since I installed one of these again due to change in company direction. But still prefer these alarms and the smartcom unit / app
Anyway onto the issue
Currently setting up a new system nothing to big
Premier Elite 64w
Smartcom
4 door contacts
4 PIR
external sounder
Internal sounder
Will be adding a garage door contact for an up and over at a later date will come back to this
Anyway the issue seems to be in the base setup
Got the unit rigged up on my test bench to configure prior to installing. Have duplicated customers SSID so the smartcom is doing what it should and I can see it in my portal. I have created user accounts but when I try to connect to the system I get “error panel has no areas”
Also when I try to connect via wintex I also get an error “connection with control panel could not be established - please check settings”
I have been through this 3 times and even factory reset Incase I messed up but still can’t get the darn thing to respond correctly.
Any suggestions before I use a hammer lol
Premier Elite 64w
Smartcom
4 door contacts
4 PIR
external sounder
Internal sounder
