Which nuclear does very little to cover. It can't scale up if there's a lull. What you want is gas with carbon captureThe basis of the nuc need comes down to it doesn't matter what number of wind turbines are installed as lack of wind still causes problems
Really?? I think it's just a case of the fact that the numbers don't stack up and the £34b would be a hell of a lot higher now,I hope that's not the 25 year old report compiled by the Nuclear lobby for the purpose of discrediting renewables.
Balancing peaks and troughs (needed to manage nuclear power and coal fired systems) isn't trivial. It saves a lot of money done right.I remember when pumped water storage was being built in Scotland, it was trumpeted as if it was an important big thing, but the actual generation figures are so small that they are insignificant, except for balancing short term peaks and troughs.
More allowing gas fired turbines to be run up. We have one finished, working and used. Dinorwig. Surplus power is used to pump water up. Running that off can help with peaks. The advantage is the speed in which they can be set to generate and for that matter top up the reservoir.Balancing peaks and troughs (needed to manage nuclear power and coal fired systems) isn't trivial. It saves a lot of money done right.
It's not very efficient. Losses pumping the water up and from then using it to generate. They also need a suitable site.The resevoir acts as a battery or buffer to manage peaks and troughs in demand and production.
Can't see why you think that from pointing out it's finished and used. It is.You write that like it's been recently finished.
It's 75% efficient which is pretty good.It's not very efficient. Losses pumping the water up and from then using it to generate. They also need a suitable site.
Interesting one as there are signs that the world is going to need rather a lot of it - at some point. That largely down to the power needed to create it. Once you have enough of it it's relatively easy to use. The problem is the green power needed to produce it in a green fashion.but hydrogen would be around 40-50%.
