Wiring a fused spur dimmer switch
13 Feb 2024
I've searched on this forum a few times and there are similar topics but I can't seem to find something for this particular issue.
I'm replacing a normal fused spur light switch with a fused spur toggle dimmer switch. The dimmer unit is separate to the switch and the fuse and I'm struggling to work out how to wire it which I hope someone can help me with. I'm a beginner to wiring/electrics and I think what I'm missing is jumping from the dimmer unit to the switch?
Thank you in advance.
I've included pictures of the back of each of the modules/units - The dimmer unit is an Enkin unit as below, the back of the toggle switch, and the fuse unit itself is below.
Years ago in the days of tungsten lights, there were supposed to be fuses built into the bulb, so if when they rupture there is ionisation the bulb fuse will rupture and stop the main fuse rupturing, and also protect any electronic switches.
However the bulb fuse was often missing, so a 1 amp fuse did give a little protection for the dimmer switch.
However when the fuse box had MCB's fitted they act in the main faster than a fuse, even 1 amp, and also faster than the fuse built into the bulb, a typical ceiling rose is rated 6 amp, so the 6 amp MCB/RCBO is in general terms good enough on its own to protect the lighting, as it is faster than a fuse anyway.
Where we have a larger overload, for example lights fed off socket supply we may still fit a fuse, but from bitter experance even a 1 amp the dimmer switch can fail first.
So question one is why is that fuse fitted? question two depends on one, is it still required?
I would assume a grid switch? To day in the main if I want to dim a light, I use a smart bulb, only with multiple lights would I consider a dimmer switch.
However I simply don't know why yours is wired that way, so can't really help.
Thank you everyone for your replies! Very much appreciated.
I've tried to mock up the diagram with the wiring as follows:
Is this right? Slightly confused as to where the earth wires go on this.
It appears to be wired off a socket supply so I assume that is the reason why it's been originally wired with a fused spur switch.
Is this right?
I don't think so.
Why have you altered the diagram and connected COM to 1?
Are you not connecting 2 to 2? A switch with only one wire cannot do anything.
Surely it should be wired as in the diagram.
All earth wires must be connected together at each accessory AND to the accessory if it is required and/or to the back box.
Yes you're right - So I would do Blue 2 to 2.
My confusion is that I will have 3 wires coming in from the Load, and 3 coming in from the Live, so 6 in total.
E.g. where would my neutral load, and where would my neutral supply enter the circuit?
It was previously wired like this as the original fuse spur switch if this is helpful?
Well, yes but it should be sleeved brown (or otherwise identified) to show it is a Line(live).
