Yes I thought that too, I never actually considered whether or not the intention was to be insulating.
Well I'm very aware of the history of these and in addition one of my duties in BT involved visiting numerous BT building, mostly exchanges, and one of the checks being the presence of the insulators and carrying a stock to replace as required, there was even a specific code on the timesheet ELPS (I assume Electric Light Pull Switch) and worth ¼hour for each repair.There's actually been quite a lot of debate about that i8n the past. Some people believe that those things are not primarily intended as "insulating devices" but, rather, are to facilitate user-replacement of most of the cord/'string' without having to delve inside the switch.
Yes, but not the current version of 'our wiring regs' but, rather BS7671:2008(2)Anyway, special locations in the building regs are special locations as defined in our wiring regs.
Indeed - in England. As you say, it's a bit different in Wales.Most homes the only special location would be a bathroom ..
Indeed. I've never been quite sure why Part P us restricted to domestic/residential properties - most of thee Building Regs applies to any property, doesn't it?Part P considers domestic to include a flat above a shop/pub so that causes some confusion for some. Some people confuse Part P applies to all "domestic premises" but some confuse "applies" with "being notifiable", in fact one of my assessors confused applies with being notifiable.
How is it different in Wales?Indeed - in England. As you say, it's a bit different in Wales.
Fair enough, but you may well be talking about the view of BT, not necessarily the 'intended' reason for the plastic thingies (probably much cheaper than the prior brass ones) appearing.Well I'm very aware of the history of these and in addition one of my duties in BT involved visiting numerous BT building, mostly exchanges, and one of the checks being the presence of the insulators and carrying a stock to replace as required,
As ebee said, in Wales they still have 'special installations' as well as 'special locations',thereby widening the scope of what is notifiable in Wales.How is it different in Wales?
I'm too busy today to spend time with nit-picking. The point, on which we are all agreed, is that there are more 'locations' (e.g.outdoors) )in Wales than in England in which, by virtue of the 'location', electrical work is notifiable.View attachment 334737
But you were referring to 'special locations' which are the same in England and Wales.
Not nit-picking. You made a(nother) mistake.I'm too busy today to spend time with nit-picking. The point, on which we are all agreed, is that there are more 'locations' (e.g.outdoors) )in Wales than in England in which, by virtue of the 'location', electrical work is notifiable.
No no noFair enough, but you may well be talking about the view of BT, not necessarily the 'intended' reason for the plastic thingies (probably much cheaper than the prior brass ones) appearing.
Is anyone aware of any regulations or legislation that actually 'requires' there to be 'insulating devices' in pull cords?
Fair enough - so can anyone answer the question I posed ...No no no ... There was lots of it about years back. ... one of the shed had been selling incorrect units and had to provide replacements.
