Is this turning into another noseall spam thread?
That's the thing when you don't have a clue what you are talking about, it's not just "slapping bricks on top of each other in a straight line".
It's the difference between a professional who has done years of training and then years of working, and an amateur or a person who has bought a white van one hour ago and touts for work.
Your lack of knowledge can't see, understand or appreciate a mundane thing like a brick wall, as it's all just "bricks on top of each other in a straight line". So of course, anyone can do that. - you need you change your name you Yosser Hughes.
And that cluelessness and disdain for proper tradespeople is most likely the root of your own attitude problems and insecurities. You think you can do the same or better, when really all you are doing is getting to some or other standard, by some or other method, and at some or other cost, and which you accept as good enough. And then all of a sudden in your mind, you are as good as any other professional tradesperson who has been training and working for years.
Lovely work, you should be proud. I'm an enthusiastic amateur, I've built a few garden walls, but I know my limits and will stick to straight lines until someone invents curved string.Have you ever had to lay a curved wall?
Out of all the trades I do, bricklaying is the one I'd say takes the longest to learn and is the most difficult to do well. Your patronising attitude smacks of extreme naivety and ignorance. Bricklaying and patios are not all about straight lines.
My big level for internal levelling/plumbing of beams, frames, setting out etc is a Fatmax XL1800mm. It's bloody heavy but oddly, much easier to handle than the previous light Stabila and does not get easily knocked or blown over or slide about. Bubbles are very easy to see from all directions. Only downside is the bubble water has faded to clear after a relatively short period of time (less than 10 years) and it's not been in the sun much.
If I was buying new levels now for internal setting out, I'd get one's with illuminated bubbles.
I got a Bosch digital level a few years back and it's great for levelling when you can't see the level. Just put it on the thing and listen for the tone. Should have got one years back. Also great for setting things (like patios) with a constant fall as you can set the angle required.
600mm. I thought it would be more versatile for the things I planned for it.Older thread but what size of bosch level did you get? I'm looking at digital levels and was considering the bosch. I was looking at stabila but heard the calibration for that one needs to be done via the spirit bubble which seems naff compared to just pressing a button and rotating the thing a few times (which I believe is how the bosch calibrates).
Now I'm just wondering if 60 or 120 is better.
Yes, reliable and versatile. It's great for the things I mentioned - when you can't see the bubble - kitchen units when adjusting the legs down on the floor, or beams and joists when packing an end for instance. Or angles, slopes.Thanks. Have you found it good and reliable since then? Was considering this or an IMEX, but dont know much about that brand tbh. Assuming Bosch is solid.
One thing I have noticed and I think it's inherent in all digital levels is that there is a slight lag between the bubble and the sensor registering level or plumb. The bubbles may say dead level or plumb but the level may need that little 1/10 or 1/100 of movement before the thing beeps.
Likewise, there is travel in the bubble before the digits move. I suspect it relates to the sensor steps being 1/100 of a degree but the bubble is analogue with no steps.
It messes with my OCD, but in context, 1/100 of a degree is nothing really for most things.
One other thing with the Bosch levels, the display has a very narrow display angle, so you need to look at it from a certain angle. Most reviews mention this.
I've never had problems with Stabila levels and the bubbles. Whilst you should always avoid tapping and bashing any level, the stabila bubbles always seem to be stable. The bubbles in some cheap levels do seem to separate easily at the slightest tap and take a while to join back up.
Have a look at the Fatmax XL levels, they have slightly curved vials and the bubble may be more stable for you.
I must confess that as I hurtle towards my dotage, I find it more difficult to see the bubble when lighting conditions are poor. I have concluded that I probably need a laser level for some tasks.
WTF's your issue?Personally I wouldn't listen to any advice on spirit levels from this character.
WTF's your issue?
