The Kitchen, photos of progress
  • Thread starter Deleted member 294929
  • Start date
As cookers they are great. They have everything including Airfry and Steam.
But tge display does not light up and it's hard to see at night unless all other lights are blazing.
Neff are the best
Yeah, we are going for a Neff hide 'n' slide with a built in Neff combination oven above. Looking at the Neff Induction hob too.
I cant see a hob
I got this and the tap cheap from Magnets. I will replace it, depending on what tye future brings. It's not a great model.
The stain on the right is from my coffee plate.
That's what Mrs B wanted but they were hard to get.
This has a fold and half fold.
That was going to be my next question!
It's a Bosch
I'll most probably get a Samsung so it matches the Ovens.
Thinking of selling so I want everything looking good to the naked Eye without glasses.
The kitchen fitter flucked up on his measurements. So I had to have a door custom made for the Dishwasher.
You can easily slice those doors to required measurements.
And before doing so, slice the edge finish off so it can be glued to the cut to size door.
The splash back fella said that same thing. But I wast convinced. If water gets in its fųĉƙèð.
I know you did.
Sorry.
The plymths are manufactured sealed where I have had to cut (under the Dishwasher) I've sealed with mastic.
I have mine so I can remove them if I drop my beer i can take them off and mop any beer up from under also if they are sealed at the bottom to the floor then any leaks from the dishwasher or washing machine will stay behind the kick boards and not be seen until damage is done
Where I've found raw exposed cuts or holes I've seal with rubbing silicon in.
I'm sure I've not got the lot but this is always a floor in kitchens if they get wet.
Unless you can afford the expensive ply.
