Thanks Harry. Few questions on this please for my understanding:
- If it turns out to be a 1.5mm cable, can this remain in place if used in conjunction with a fused spur and would the fused spur need to be installed at the JB before the 1.5mm cable commences or does that not matter?
- Although not pretty, is it possible to used a switched fused spur as regular light switch? Then a quick fix would be to swap the existing light switch with a switched fused spur
- I assume a fused spur unit always needs to be accessible for inspection and cannot be buried inside the wall? Feels a bit overkill to install a separate fused spur switch in the wall for 7w of LED lighting. It's in my son's room and he never uses this, so might do away with it completely.
