Inbuilt TV amplifier?
6 Nov 2023
My Phillips CRT tv has speaker connections at the back and I was wondering if I can hook up a pair of passive speakers to it? If I can't then why does it have those connections at the back? _20240405_182603.JPG
Early surround sound?
Surround sound "effect"! :)
Plus, of course, as this TV doesn't have any built-in speakers, the front L and R speakers (which are detachable from the TV sides), would also connect here...
It sort of makes you wonder how he heard any sound from the TV in the first place, if he didn't know what the connectors did :unsure:
I have been hearing sound from the TV for the last 5 years without any external speakers! This TV has got inbuilt speakers. I think the connectors might be for external speakers but with low output wattage?
Could you show us a picture of your actual TV, rather than a copy and paste from here?
Without assurance, I wouldn't like to experiment on my newly bought 300W sub.
Yes, the TV will take passive speakers. That was the idea. You could do with some that are fairly sensitive to make the most of the available power from the TV. Aim for 89~91dB/W/m (A.K.A. 89-91dB at 2.83V).
Regarding the sub, you'll need either a sub with a speaker level (hi-level) input, or a TV with a line level output that tracks the volume setting.
Hang on, are you the guy that was posting about surround sound the other day?
THIS is why your TV spec says it has it, you have to plug in external speakers to put at the back of the room!
And no, the spring clip connectors aren't for the sub, you should use the Left of the phono outputs to the right of the speaker terminals
