The unidirectional device has the word 'out'. There are no markings on a bidirectional device.
So I came to realise following flamport's post. !BEAMA published a tech update last year and there was an article in wiring matters 99. The term is unidirectional, not omni.
Thanks, but what does "works in both directions" mean in this context?..... Hi-directional means the device works in both directions so is suitable for prosumer units.
I'm getting very confused. Are you perhaps saying that all the RCDs which we 'know, love and use' are, in fact bi-directional, and that it is unilateral ones, if they exist, that are rare (and, as bernard has suggested, would probably be quite complex to produce) ?Unidirectional devices have an indicator to show the direction from supply to load, such as an arrow.
I looked at @flameport example andThe unidirectional device has the word 'out'. There are no markings on a bidirectional device.
Well in a nut shell devices cant know which direction the current is flowing as it changes 50 times a second.I looked at @flameport example and View attachment 342535is shown on the bidirectional. It is all well and good buying new, but when doing an EICR how does one know if the units fitted are OK.I can see the problem however it also says MCB's and I had never considered a MCB could have a problem.
Do you mean 100 times per second ?Well in a nut shell devices cant know which direction the current is flowing as it changes 50 times a second.
A device could use separate current transformers ( one on Live and one on Neutral ) and a voltage comparator to determine the difference if any between the Live and Neutral currents. Most MCBs use a single current transformer with Live and Neutral in antiphase through the coreWell in a nut shell devices cant know which direction the current is flowing as it changes 50 times a second.
... so, are they suggesting that "bi-directional RCD" means "RCBO" -, 'because' it provides over-current as well as residual current protection ?From the first of Flameport's links.
So - either another totally inappropriate name for an electrical item or possible an inaccurate translation from the original.
That would be great, if he could do it - but that would require that he understands what a "bi-directional RCD' actually is (assuming it's different from the RCDs we know) - which may or may not be the casewell its got me flummoxed too. ... just a thought - I wonder if someone on this forum could ask the esteemed JW to do one of his excellent youtube articles for us mere mortals![]()
Thanks. That seems to be saying that an RCD can be assumed to be bi-directional unless they have in/out markings, arrows or whatever to indicate the intended 'direction' of installation. None of the RCDs (RCCBs) I have here bear any such markings and, as I wrote, we frequently see people being advised that RCCBs can 'be installed either way around'.this may help.
This Wiring Matters article seems to confirm that most (maybe all?) RCCBs are bi-directional, but suggests that at least some RCBOs and AFDs may not be - but, again, I find it hard to understand how the latter can fail to respond to residual currents in either direction.As may this
So it seems we are back to square one, we know what the problem is when connecting to power supplies through a unidirectional in that parts can remain energised after the device has tripped, however I still have no idea how to look at a device already installed and see if it is bi or unidirectional.Wiring Matters March 2024 Bidirectional protective devices said:A protective device that does not have markings to indicate line and load terminals is a bidirectional device
