- Joined
- 27 Jan 2008
- Messages
- 28,411
- Reaction score
- 3,453
- Location
- Country
My cat flap started flashing a red LED which is on the chart a signal of discharged batteries, so I changed them, 4 x AA cells, the flap has not been in use long so measured old batteries after changing, and 1.4 volt each.
So looked on internet and found
But most seem to say "At 1.2-1.3V is typically when most 1.5V batteries start to become weak." and it does seem many bits of equipment report the battery being below useable voltage at around 1.3 volt so will not run on rechargeable cells. The Leclanché cell we taught about at school, and we have:-
– anode (oxidation of Zn): Zn → Zn2+ + 2e− | E0 = −0.76 volts
– cathode (reduction of Mn(IV)): 2 MnO2 + 2NH4+ + 2e− → 2 MnO(OH) + 2 NH3 | E0 = 1.23 volts
So producing a theoretical voltage of 1.99v of potential energy across the terminals. A variety of factors, such as internal resistance, lower this output value to the 1.4 volts measured from these cells in practice. But in that case my cat flap should have been working OK. But today cells are often not simple Leclanché so in real terms no idea what voltage I should be looking for?
Most of the instructions relate on cutting a hole in the door, bit on how it works is reduced to
which is very little is says "Remove the battery cover, set aside the provided hardware pack, and install 4 high quality alkaline AA batteries (LR6). The green LED light will flash three (3) times which indicates that the cat flap is in Automatic Mode." I have looked and there seems to be a whole range of batteries which say they are alkaline AA cells, often with trade names like Duracell which it seems are designed for rabbit hatches not cat ones, but no details of how much energy is in them.
Five times what? I see statements like "The Leclanché battery wet cell was the forerunner of the modern zinc–carbon battery (a dry cell). The addition of zinc chloride to the electrolyte paste raises the e.m.f. to 1.5 volts. Later developments dispensed with the ammonium chloride completely, giving a cell that can endure more sustained discharge without its internal resistance rising as quickly (the zinc chloride cell)." every make seems to say they last longer, and price does not seem to help, Duracell Procell Constant AA LR6 PC1500 Batteries | Box of 10 for £3.29 and what seems to be same product £8 elsewhere. And Duracell +100% Plus Power Batteries AA at £6.50 for just 4, click on specifications and it says nothing of any use.
Some do say "for low drain devices" but nothing to say what is low drain, my TRV heads take 2 x AA cells and will last around 2 years, I normally swap every year, but the app shows 2.83 volt etc. and they seem to go to around 2.5 volt before it says change battery.
There seems to be so odd ways to test themAt what voltage should AA batteries be replaced?
Notice the voltage reading on the voltmeter. If the reading is more than 1.3V for alkaline battery (not rechargeable battery) then the battery still has some juice left in it, don't throw it away. Otherwise, properly discard of the battery.
and even seen some using the amp range, which seems dangerous to me.Alkaline batteries bounce when they're going bad, so drop one on a hard surface to see whether or not it bounces.
which is very little is says "Remove the battery cover, set aside the provided hardware pack, and install 4 high quality alkaline AA batteries (LR6). The green LED light will flash three (3) times which indicates that the cat flap is in Automatic Mode." I have looked and there seems to be a whole range of batteries which say they are alkaline AA cells, often with trade names like Duracell which it seems are designed for rabbit hatches not cat ones, but no details of how much energy is in them. Five times what? I see statements like "The Leclanché battery wet cell was the forerunner of the modern zinc–carbon battery (a dry cell). The addition of zinc chloride to the electrolyte paste raises the e.m.f. to 1.5 volts. Later developments dispensed with the ammonium chloride completely, giving a cell that can endure more sustained discharge without its internal resistance rising as quickly (the zinc chloride cell)." every make seems to say they last longer, and price does not seem to help, Duracell Procell Constant AA LR6 PC1500 Batteries | Box of 10 for £3.29 and what seems to be same product £8 elsewhere. And Duracell +100% Plus Power Batteries AA at £6.50 for just 4, click on specifications and it says nothing of any use.
