- Joined
- 27 Jan 2008
- Messages
- 29,249
- Reaction score
- 3,588
- Location
- Country
If I had a modulating boiler able to use OpenTherm
I would not even consider Hive, I don't I have an oil on/off boiler so Hive for me is a consideration, however a Hive TRV head is similar price to a Wiser TRV head, and the big expense is the TRV heads as you have, or at least I have so many, so why spoil the ship for a halfpence of tar?
I would hope where we see an OpenTherm enabled boiler with on/off control it is because the boiler has been changed without updating the controls, so I would expect to find a wiring centre which is a remnant left behind when new boiler fitted. Have a look where likely there was originally an airing cupboard.
One could put Hive where the programmer is, and turn old thermostat to max, or replace old thermostat with a blanking plate and link the controls there, however the question is where will the Hive go? Hive is designed to receive a "demand for heat" from the TRV's as long as where it is located is not over 22ºC, so located in the hall likely fine, as we would not normally have a hall that hot, but in the living room can be counter productive as if living room hits 22ºC then it will stop heating other rooms.
As to geofencing and lesser methods of remote control, I have found the recovery time for my heating is too slow, with simple times I can set a sequence so rooms heated in the order they are used, but geofencing all rooms turned on together, and my Nest Gen 3 turned down my central heating when the EE mast was damaged in high winds, so now feel simple time setting are the better option.
The thing I have looked at is the claims of what the TRV heads will do, they are the devices which control each room, so unless living in an open plan house, homes with doors on each room the TRV is king. And the Wiser TRV claims some really good algorithms to ensure rooms up to temp on time.
There is also Honeywell Evohome, and Tado (If correct on selected) which work with OpenTherm, but Drayton Wiser uses same back plate as Hive.
I would not even consider Hive, I don't I have an oil on/off boiler so Hive for me is a consideration, however a Hive TRV head is similar price to a Wiser TRV head, and the big expense is the TRV heads as you have, or at least I have so many, so why spoil the ship for a halfpence of tar?I would hope where we see an OpenTherm enabled boiler with on/off control it is because the boiler has been changed without updating the controls, so I would expect to find a wiring centre which is a remnant left behind when new boiler fitted. Have a look where likely there was originally an airing cupboard.
