Just a quick one if I may ....
Having a combi boiler fitted and taking out the traditional hot water cylinder along with its immersion heater.
The house was built in 1996 and has a pretty conventional wiring set up - consumer unit with up and down lights and up and down ring mains. In addition there's a 16 amp MCB in the consumer unit that is marked "Central Heating' and supplies both the immersion heater AND the power to the heating timer/pump /boiler.
My question is this ..... when the HW cylinder (and immersion heater) is removed the switch and cable that supplied the immersion heater will no longer be used. Is it permissible to use that circuit to connect a 40 or 80 watt Dimplex tubular heater which is proposed to provide some heat in the airing cupboard? The Dimplex comes with a three pin plug pre-fitted but I guess it would be OK to remove the plug and wire it into a fused connection unit with flex outlet.
That's it really. Although I was a bit surprised to see that the one 16amp circuit fed both the heating AND the immersion heater ... perhaps that's entirely normal?
Anyway, thanks in anticipation .
