65mm Square Downpipe to 82mm Round Adapter?
13 Mar 2010
Would this be better in the plumbing section?
The bottom of the square downpipe was mortared into place. This has now cracked & split to reveal the bodge underneath. Sunk into the concrete is a black plastic pipe with an approx 82mm internal diameter. The square downpipe just sits on this so I need a proper solution to connect it. So far I've failed miserably to find an adapter, so can anyone please help with identifying one or coming up with a creative solution?
Best I've come up with so far is trying to find a cap that will fit the round pipe, adding a square to round adapter on the bottom of the downpipe & then cutting a 65mm hole in the cap. But to do that I need to know exactly what size the round pipe is, as access is tricky until I strip it all back. And I don't want to do that until I have the parts to finish the task.
Edit
A bit more digging seems to confirm the the pipe in the ground is likely 82mm with a "socket". This is the closest I've found to my needs, other than it being round & the worst possible colour given it will be on show. Ideally want white or black at a push.
Edit
82mm? WTF.
