This morning, I finally got the Chinese ceiling fan/light last niggle sorted. I had it working just fine, via it's own remote control, an hour after fitting the unit, but it was suggested to also be controllable, via an app.
There not many clues as to which app worked with it, or even how to set it up. There was a QR code, but that led to an app to control a fancy coloured light range, but not a fan and light, that I could see. A similar named item, from the same company, was the one needed, but then how to get it to pair to the unit?
It claimed to be bluetooth, some buyers mentioned power it off/on, then you have 5 seconds to pair. But no additional bluetooth showing in my phones settings. I finally cracked it, this morning....
You run the app, give it permission to access bluetooth, then power the unit off/on, then press a button in the app itself, to get it to pair - all within 5 seconds.
It's quite a clever unit. Fan has 6 speeds, forward or reverse. Light has infinite levels, from incredibly bright, to dim - but the dim could do with being a little dimmer. Colour temperature is variable between very white, to yellow - only three colour settings at dim, but colour range extends, as the brightness level increases. Then there is a runtime setting, to turn it all off, after a while, so it's not on all night.
If you turn it off at the wall, then turn it on, the light comes on - a bit of a problem, if you go away on holiday, and you suffer a power cut..
