Hi, I would like to run an ethernet cable between two detached buildings at first floor height. There are tiled roofs on both and each building also has a window facing the other.
I'm undecided as to whether the cable will run through window PVC across to the other, or through a drilled hole at attic/loft/roof height.
I would also imagine it is less work to simply run the cable across both buildings in the air - rather than out the first floor, down the outside, bury into the ground and then reverse the steps to the other building.
Therefore, my question is asking what is the easiest way to get the wire across one building to another building in the air? Ideally the simplest method for one experienced DIYer and maybe some novice help. Thank you!
