Need to run ethernet between buildings at height
  • Thread starter Thread starter FTR
  • Start date Start date
FTR
8 Sep 2024
Hi, I would like to run an ethernet cable between two detached buildings at first floor height. There are tiled roofs on both and each building also has a window facing the other.
I'm undecided as to whether the cable will run through window PVC across to the other, or through a drilled hole at attic/loft/roof height.
I would also imagine it is less work to simply run the cable across both buildings in the air - rather than out the first floor, down the outside, bury into the ground and then reverse the steps to the other building.
Therefore, my question is asking what is the easiest way to get the wire across one building to another building in the air? Ideally the simplest method for one experienced DIYer and maybe some novice help. Thank you!
Won't that add its own problems for people carrying tall ladders for example?
Do the two buildings have a common boundary or is there some land between them that is :-
(1) owned by a third party
(2) crossed by a public right of way
(3) crossed by a vehicle access.
If (1) then you will need to arrange for the grant of a wayleave for the cable
If (2) or (3) then the mininum height of an overhead cable would be 5.8 metres
Need more information really but as it’s CAT 5 or 6 then the electrical regs don’t apply
Common sense does apply in big doses
No issues regarding ladders, boundaries and height should be above 5.8 metres.
This is more of a practical question of how to actually do it easily and efficiently please
Catenary cable with good fixings. Cable drilled out at specified points and suitably tied to catenary
What is it you need to achieve?
There are many ways to approach internet or network connections in buildings.
For example I have a few customers with out buildings but the supplies to some of these buildings on the same phase so easy to use Ethernet over mains plug
Some are on different phases which means alternate solutions may be considered but prefer not to dig trenches or use overhead cables
So can use a mole to run the cable.
Or beaming signals between the two points.
If we know what the end game is might get done more detailed answers
What’s the distance between the two buildings
There is maybe 7 metres between the two buildings.
Mains plug or others internet options are not preferred. Ideally this ethernet cable is used for data transfer and internet. The question is more of a practical one of running a wire across
As you say you have access to lofts either side I would run from loft to loft as that puts the cable higher and further out of harms way. a catenary kit is quite cheap
and I would put the catenary below where the cable exits the building so water cant run along it
(and run two cables not one just in case!)
