- Joined
- 27 Jan 2008
- Messages
- 28,207
- Reaction score
- 3,424
- Location
- Country
Last house I removed the cylinder as it gave me more room, in fact enough to make the airing cupboard into a room after moving a wall and taking some space off the landing. However this house the cylinder was there and now with solar panels in summer we use the immersion heater to give us free domestic hot water.
As part of the solar system I have a unit called an iboost+ which controls the hot water, and also reports how much power used. Last 7 days 2.44 kWh, the big question is how much energy is used by the gas instant heat boiler to heat the heat exchanger, it clearly changes boiler to boiler, but the whole idea that gas is cheaper than electric assumes the boiler is 90% efficient which it may be with a 3 hour burn, but a 2 minute burn unlikely, it is likely cheaper to fill a bath with gas boiler, but to wash ones hands, unlikely. And if you have tried filling a bath with a instant heat gas boiler, oh it is super slow.
I was told many times it was cheaper to heat DHW with gas or oil, once in a position to check the claims, found it was not true, while CH running yes very likely boiler already hot, in summer no it's not.
