Indesit tumble dryer intermittently spinning
25 Sep 2013
Nottingham
Hi, I have an indesit condenser dryer. I noticed last night that when I press the button to switch on the machine makes the usual noise like there's power but the drum doesn't spin, or spins for a while then stops. I tried again this morning and there was a little smoke and burning smell that looked like it came from the control panel area (could be wrong) so I switched off and removed the plug. I removed the top and there was loads of dust in there so I gave it a good hoover out but couldn't see any burnt out components on the back of the control panel or anything else that looked damaged so I plugged it back in and gave it another go and it started spinning. This lasted for about 10 minutes and then it stopped spinning again. What can I check? It doesn't't seem terminal to me so I don't really want to throw it out just yet if it can be fixed.
Try plugging in somewhere else to eliminate fused spur or socket.
They can burn out causing issues because of the amount of power pulled.
Check the fuse in sealed plug is clean and seated tight.
Actually when I changed the socket thats when it started spinning for 10 minutes or so then stopped. Fuse is fine.
I am only guessing... I might be the motor capacitor. The capacitor provides the "boost" required to start the drum spinning. Sorry, you may be aware of that, but others reading this post might not be.
My heat pump tumble drier recently stopped working, It made a buzzing noise but the drum would not spin. I partially stripped it down, pushed the drum clockwise and it started spinning.
I popped down to Capitol Repairs in Rayners Lane. They gave me a generic capacitor. Less than a tenner. The machine started working immediately.
The capacitor is the same kind of diameter as the cardboard interior of a loo paper roll. It, in my limited experience, has a threaded bolt with a nut to hold it in place next to the motor.
If you don't want to pull it out again to test it, you could possibly open the door and wedge a screwdriver into the door lock to trick it into thinking that the door is locked, and then use your hand to start the drum moving.
That’s interesting, when mine stopped after the 10 minute period I gave the drum a little push and it started up for a while like it was really trying to start up again but couldn’t quite make it.
I’ve just tested it and of course it’s started up again no problem for the last 20 minutes. I’ll put a load in this evening and check again to see if that makes a difference and if I can get to the capacitor I’ll check it with a multimeter.
TBH, I don't know how to test a failing capacitor with a multimeter.
For what it is worth, my capacitor was, as you look at the machine, on the bottom right hand side of the drum where the motor is. I have only repaired about 12 washing machines and tumble driers. In each case the motor was bottom right.
Flashing lights or lights permanently on is an error code.
You don't need to have a digital display
Annoyingly since you posted I have managed to do two loads of drying with no further instances of it not starting. My fault was strikingly similar to yours though so I took off the side panel and located the capacitor which is exactly where you said.
It's an 8.5uF capacitor +/- 5% but when I measured it, it was only reading 3.3uF so I suppose that must be my issue. As long as your multimeter can measure capacitance then you just test it by touching your probes like you would resistance.
Thanks for the help
