Hey knowledgeable folks. Currently exploring what's needed to replace a very (VERY!) old CU. Early stages, so only rough conversations with some local sparks to get their opinions and already hit an immediate conflict.
We have a 100amp fuse on the service cut-out, feeding into main isolator via meter, and then on to the old CU. As well as being v. old its in a ridiculous position, shin height on the return wall of a very small pantry room. Far from ideal. Plan is to run SWA from the main isolator ~3m and fit a new CU at chest height in a large cellar space. Should be much easier to work with then, as well as being more central to the house.
The question: I've had 2 suggestions for the SWA from cut-out to new CU - 16mm and 25mm. Before I let the sparks battle it out with pugil sticks, what's the forum hivemind think?
