You should have bought a better mask
Buy a longer hoover pipe and put the hoover outside
Use a longer handled brush, so youre not in the cloud, wet the dust before you sweep it up and don't move the brush quickly. Use a vacuum cleaner instead
True, this is a good idea for a broom. I was using a dustpan and brush so it didn't take much to get it soggy in the sink.Erk, sounds quite wastefu lof water. Might have been better to leave it soaking in a tub?
Lol! I read it online somewhere.Yep, speed is your friend. On board so far...
WTF!
That's a really good idea - will give it a whirl if I can find one![]()
Examples
Flexible 15 Metre Length Hose Coil 38mm Diameter For Goblin Vacuum Cleaners | eBay UK
Industrial length vacuum cleaner hose coil. Whether youre looking for vacuum cleaner parts, tumble dryer spares, dishwasher or washing machine components, or even microwave and cooker hood accessories, weve got you covered.www.ebay.co.uk
5M NUMATIC AQUAVAC HOSE 51MM DIAMETER HOOVER VACUUM CLEANER HOSE 5 METRE 34252X5 | eBay UK
VACUUM CLEANER HOSE. CAN BE CUT TO REQUIRED SIZE.www.ebay.co.uk
I believe trade suppliers buy the hose on big reels, and cut it to the required length and fit the end pieces.
Would you care to put some numbers and science behind that, rather than leaving it at a somewhat sensational but unqualified "quite dramatically" ?just be aware that your suction power will reduce quite dramatically with a long hose due to friction losses.
